Alternator Freezes Up
RFerraro
The alternator on my 20 year old Renault 2.60 Diesel was frozen when I tried to start the engine for the first time this Spring. The v-belt spun and got chewed up while the alternator pulley refused to turn. Gently tapping the exposed fan blades with a hammer finally loosened the alternator, which then spun freely and operated normally. After a few weeks of normal operation it again froze this weekend. Once again it took some gentle taps to get it freed up and working. Anyone know what could be going on? Is this just the typical sign of an alternator about to die? If I want to replace it with an after market rebuild how do you determine the correct size etc? Any ideas appreciated.
Ross
Jun 15, 2004
14,693
The bearings are probably going bad,
lost their seals and grease. If you have a good automotive shop nearby they may be able to replace the bearings or rebuild the unit or find an exact replacement.
C
Chris
If it's a Bosch unit, rebuild it.
If it's an American unit, rebuild it. If it's a Paris-Rhone unit don't bother! The bearings all have numbers on the outer race, you can have an auto parts store cross ref the numbers and get you replacement bearings. One of the ceiling fans in my house has alternator bearings that I put in and that was 20 years ago!
RobertF
Thanks
Thanks for the responses. I appreciate your time and will check the bearings this weekend.
