Looking for alternative wiring scheme for a Seward Water Heater (F700 with heat exchanger). Much to my disappointment, my 1981 Hunter 33 old Yanmar engine does not have a heat exchanger, and we would like to have the capability of having hot water when not in port. Right now it is wired to the ac panel and works fine when in the dock. I have a 2500 watt inverter system, the specs say it requires a circut with a minimum of 1500 watts.
1) I assume there is no way to use the fresh water cooling system through the water heater's heat exchanger system ?
2) Is it possible or advisable to simply change the electrical inputs from the ac panel to to the inverter ? Use only when the engine is running
3) Is there way to wire this to select between the AC panel when in port and the inverter when under power (best of both worlds) ?
Thanks
Jim
Thanks
Jim
