The Great Anchor Debate
Your first mistake is evident in what you say: "economical alternate anchor". As Ross says above do NOT compromise on your anchor. You get what you pay for. This means avoiding all cheap Asian made imitations etc - and if an anchor such as a Spade is expensive, there's a reason.Safety and security equipment is a necessity on your boat and should never be compromised. You must accept it as a proportionate cost - the larger the boat or the more adventurous your intended cruising, the greater the investment necessary in the right gear. C'est la vie. Applies not just to anchors.If you buy a $50 cast Chinese claw copy, you deserve no sympathy when your boat or your own safety is threatened later on.Your second mistake (no offence intended here) is to request opinions on anchors on an internet forum. This is right up there with piracy, guns-on-board, and political debates. The reality is very few people have the experience necessary to give you good advice. Identify your priorities, identify the choices available, and conduct your own research.Having said that, here's my 2c:Claws are usually recognized as being good setters, but have limited holding power, especially in mud. Steel Spades have an excellent reputation and do well in tests. Plows like the CQR are somewhere in the middle. Danforth types are unpredictable. Newer designs like the New Zealand designed Rocna (mentioned in another thread) are probably worth considering. They are made in Vancouver.Good luck.
