That is what happened to me too Roy! I saw the fuel back up near the deck plate and figured that that was good and full...the next day all that fuel that was above the top of the tank was happily floating in the bilge!!!
Chris
groundhog groundhog1rb@... wrote:
Hi Richard,
Going by memory here..
But as you are looking toward the engine and down on the fuel tank hatch, the hose fitting on the left is the only one with a clamp. I think that one is the return. Then the middle one and farthest forward, is the fuel supply to the engine. This is a threaded connection. Then on the right is the vent.
The only one they did right is the one where all they had to do was cut a piece of hose (no connectors).
By the way, if I fill my tank up too much, like until I see fuel in the neck of the fill on deck, it will leak into the boat somewhere. I can only fill to the top of the tank.
Roy
#1813
Chris
Hi Richard,
Roy
#1813
