O'Day 25 Solataire
I enjoy sailing my O'Day 25 either with crew or alone. The boat is a shoal keel-centerboard model, used (thus far) on a fairly large inland lake. It is kept at a tight slip in a crowded marina. The space between the slip piers is about 20 ft, and two craft must fit in that space. Several tight right angle turns are necesssary to embark from the slip and to land.The sail collection includes main, headsail (jib), 155% Genoa, and asymmetrical spinnaker. Headsail and Genoa are flown with standard hanks. I have a topping lift on the boom so that it stays in place without the main set. There is a 15 hp Johnson outboard for auxiliary power.The first time that I launched the craft (after purchase this year) I sailed it single-handed. The most difficult challenge to overcome was leaving the slip and landing. The 5,000 lb boat does not exactly turn on a dime or stop/start instantly. Leaving the slip, I proceed as follows: 1) take off and stow main sailcover (I leave it shackled to the halyard); 2) clip headsail to halyard and clip all hanks to headstay; 3) bunch up headsail and bungee cord to bow pulpit; 4) run headsail sheets to cockput; 5) verify fuel supply/fill gas tank if necessary; 6)start outboard and wait until it is running warm and smoothly; 7) with outboard running in neutral, undo dock lines and manhandle boat until bow is pointed in the right direction; 8) jump aboard, place outboard in forward and steer (with tiller) away from slip and down navigation channel to deep water in lake, away from traffic and pointed to windward; 9) place outboard in neutral and lower centerboard; 10)raise and cleat headsail (sheets are loose but not excessively so to avoid fouling sheetlines from 'flapping'); 11) slack mainsheet and raise mainsail; 12) adjust outhaul, downhaul and boomvang; 13)turn off and raise outboard; trim sheets and sail away.Returning to the marina is pretty much the reverse of the above, except I just bungee the main to the boom and fold and stow it in its cover at the slip.Probably the biggest challenge with all of this is learning how the boat responds to helm under auxiliary power, and the process of landing under power. Reverse of the outboard is necessary as I near the slip pier so that I gently arrive, at which point I put the outboard in neutral, jump up on the bow, grab a dockline, jump on the pier, and make fast. In travel within the marina corridors I have learned that use of the tiller is generally best, with outboard amidships (vision is better for one thing) but that use of the outboard directly for steerage is best for emergency or quick maneuvers. Sometimes I have maneuvered in the marina in reverse for better control and maximum vision. A significant problem in single handling is the lack of a crew to man the watch.I have also leaned to reduce sail to avoid problems with less human movable ballast. No problem at all in light to moderate air, but with a brisk breeze I will reef the mainsail and headsail and at times sail with just a headsail. Obviously I do not fly the asymmetrical sail without a crew. I can imagine this could be done with an autosteerage arrangement. I believe single handling would also be easier with a self-furling headsail. Also, safety is a particular concern, as falling overboard while single handling could be a disaster.In summary, I enjoy the accomplishment of being able to single handle the O'Day 25. One must do the jobs of both skipper and crew, being constantly on the watch for other boat traffic, keeping all lines and gear ship-shape, etc., but the solitude is a pleasure.Happy sailing!
