I've been hearing some squeaking as my boom swings around at the dock. I'd lubricated the gooseneck before but today I noticed a potential disaster in the making. A pin at the gooseneck which rotates in a socket had worn nearly through which would allow the boom to part from the mast!Mine is an '87 H23 with the Z Spar mast and boom. The fittings are a soft "pot metal" and will wear if rubbing against stainless fittings. I had a similar problem with a vang shackle at the mast base. Anyway........I think the wearing problem might have been caused by my boomkicker which pushes the boom aft and allows it to bob around constantly. I do tie it off laterally but without a topping lift the boom bobs up and down causing constant wear on this pin.I'll attach a picture to show where the problem is. You can't see the damage as I've removed the boomkicker and reinstalled a topping lift until I can get it repaired. I liked the boomkicker but not if it's going to cause me to loose my boom. Any thoughts? Is the boomkicker simply too long?
