I have a new to me 1981 S2 9.2A on the hard down in CT. During survey, it was noted that in neutral with the cutless bearing lubricated with water, the shaft was hard to turn. The surveyor has extensive sailboat experience, which is why I hired him.Looking at the back of the cutless bearing it is obvious that the shaft is out of alignment down and to the left depressing the cutless bearing at about 7 o'clock. The opposite, of course, is true at the front where it is compressing the bearing at about 2 o'clock.Another survey issue was loose engine bed tabbing, which has since been repaired. I have hired a diesel mechanic to look at the alignment issue, but to be frank, they don't seem very experienced with anything aft of the transmission.From online research, the vertical alignment can be adjusted by raising and lowering the adjustable mounts on the yanmar 2QM15. However, the left to right adjustment seems to be accomplished by loosening the bolts holding the mounts to the beds and then nudging the engine somehow with a lever. Is this an accurate account of what is entailed to accomplish the adjustments? I was going to leave it to a mechanic as I understand that the fit between the coupling halves has to be 0.001 inches per inch of coupling surface. However, if I can't get a mechanic out by this weekend I think I will give it a shot. Thoughts and advice are appreciated. Shifting the engine to port will be a blast as the galley cabinets are on that side of the engine.Also, regarding the cutless bearing. It does not seem to be worn, but it is under such a crosswise load it may be tough to judge. The surveyor seemed to indicate it could wait a season, but it certainly seems that the better part of valor would be to replace it or it will cause vibration even after the alignment. I have a friend who has one of those remove the bearing while its on the shaft devices for his Catalina 30, which he has had mixed luck with (he said next time he would just pay the 300 to have it done). I thought I might try that. The yard it is in is in disarray and isn't even capable of returning a phone call, never mind working on a boat. The other option is, of course, to pull the shaft. However, the coupling is so totally rusted that I can't imagine that being possible, even if I could reach it comfortably, which I certainly can't on this boat being a 6 foot 230lb type. A friend suggested just biting the bullet and replacing the shaft, coupling and cutless bearing, but I feel like I will be digging such a hole for myself I will never hit the water. Plus the boat is in an unfriendly yard two hours from home and I can only spare about six hours a weekend plus travel to work on it. The complicating factor is I need the boat to make a three day journey back to Boston from Long Island Sound including a passage through the Cape Cod Canal. One thought is to do the alignment work, splash it, see how bad the vibration is (if one can even tell from the normal vibrations people tell me to expect from this engine)and, worst case, move her to a nearby sailboat friendly yard for repairs.In any case, I plan to clean up the coupling as best I can and try this new cryogenic penetrating spray I picked up to see If I can loosen the shaft after all.Sorry for the long post, but I wanted to provide all the background I could to facilitate thoughtful responses.Thanks in advance for the wisdom.BobM
