I am replacing my Yanmar 4JH2E motor mounts and have a question.
I have taken all the bolts/nuts off for the transmission to shaft flange. It was separated about 1 year ago and the bolts came of easily. There is no apparent rust at the flanges. I have a PSS dripless seal.
I know I need to get a little space between the flange surfaces to allow movement/measuring the clearance. I can't seem to get the flanges to separate and move the shaft back a little. I don't know if it is because there is some kind of 'binding at the flange faces or if the spring force on the PSS diaphragm is holding the shaft forward. Any thoughts?
If anyone has had this problem or just know how to get the space so I can continue?
