A
Al
Have a 1995 Hunter 420 Passage, with a Isomat mast --- found defective welds around bottom spreaders.The break is unusal -- it is in the middle of the weld bead which hold the base of the spreaders.Of course, with a partial breaks in the weld you could lose the strenght at any time under sail, then you will lose the spreaders and most likely the mast.If you know about this, or have had the same problem please let me know.Beware,al
