Alder Barbour /93 Hunter 33.5
13
Hunter 33.5 Ladysmith
The Adler Barbour fridge on our '93 Hunter 33.5.Work's well on AC shore power.But the Fridge will not switch over to DC when shore power is disconnected.Has any one had a similar problem.!:cry:
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Check
The 12 volt unit is a seperate unit so look there at all wire connections and any corrision.
nick
Jun 2, 2004
217
Hunter 376 Oyster Bay, LI, NY
Not to contradict Seadaddler but I'm pretty certain that all the AB units are DC powered. Having said that, have you double checked whether 1) your batteries are truly getting charged through shorepower, and 2) whether those batteries are actually holding the charge. What could be possible is that, while plugged into shorepower the pushing the amps through the charger and batteries so your refrigeration would work fine. But when you unplug, that "source" isn't there anymore and there's not enough 'juice' in the housebank to power the compressor.
The first thing I'd do would be to put a meter on all the connections (and check them while your at it!) and make sure the proper 120V AC power is coming out of your charger and into your batteries. If all is good there, do a load test on the house bank and make sure they can charge fully, and then hold that charge.
Sep 29, 2009
12
Hunter 33.5 Iron Mountain Marina, Degray Lake, AR
Adler Barbour
My '93 33.5 has an A.B. fridge, but it's strictly D.C.
I'm having a trailer built for mine and need some measurements. I wonder if there is any owner out there who might have those figures already.
Nov 15, 2010
13
Sea Freeze SF2000 AC/DC
My apologies this unit is a Sea Freeze SF 2000 AC/DC.It works well on AC,but will not work on DC.
