Stove Repair
Jim,I assume your stove is an Origo 1500 non pressurized alcohol stove.They are pretty simple, but one thing I am aware can happen is the gasket covering the fuel canister sticks.When you turn the knob of the stove, a metal plate slides either covering or exposing the fuel canister. When the knob is open, you should be able to look down the burner and see the fuel canister. If you see nothing but black rubber, the gasket is stuck. Remove it and get a new one from West Marine for $4.00.If you have other problems, please elaborate.Hope this helpsWard
