ALCOHOL STOVE
jerry
This is my first season with my newly purchased ODay 28. It is equipped with a Seaward "pressurized alcohol" stove. My previous Hunter had an Origo alcohol stove, but this is something else. Are these things safe? Any suggestions for a substitute replacement?
Ben Allen
You Have The "Curtain Burner"
From what I have heard, with a little practice, they can be operated safely. I never had such luck. When I bought my O'Day 26, it came with the same stove, and I had heard of their reputation. I removed the stove and set it up on a work table in our carport. Following all the instructions: 1. Pressurize the tank with about 20 pushes 2. Let a little fuel drip into the catch basin 3. Turn off fuel supply, and light catch basin 4. Once catch basin is heated up properly, open fuel supply 5. Cook meal After trying for over a week, I was never able to get anything less than a 2 foot flame at ignition time, and this stove is located just below the curtains. My solution was to go to Wal-Mart and purchase a small propane powered Coleman camp stove. I removed the guts from both the Coleman stove and the Seaward stove and place the propane components in the Stainless Steel Seaward stove. Now I screw on a small disposable propane canister, light the propane fuel and cook my meals. One word of caution, propane is heavier than air, when not in use, keep the propane canisters located outside, mine are in the fuel locker. Ben Allen Montgomery, AL "Latte Dah" O'Day 26
Dave
Origo
I loved my two burner Origo stove on my old Cat 25. I also ripped out the pressurized unit. The Origo fit right in the same spot. These things are so simple it's hard to believe anything could ever go wrong. Unfortunately the heating time was a lot longer than propane...try boiling a pot for cooking lobsters with an Origo, your in for a long wait. Otherwise they are GREAT as Tony the Tiger says. Dave.
m steffen
I have the same question
please advise if you get an answer to your question - I have been told my alcohol stove on my 85 oday 28 is dangerous - never have used it - but would like too - I am afraid. Please advise
