Albin motor in Argentina
ssolda
Dec 16, 2008
5
Hi everybody! My name is Santiago, I have a 30 ft sailboat in Buenos
Aires, Argentina, who has an albin motor O22. I don´t have the
original manuals, but I find a sweedish one on the web. It´s a bit
difficult for me to undeerstand. Maybe someone has an english version
of it.
Another thing is that I must change my spark plugs and I think I don´t
have the right ones. I tried to read the Swedish manual and it says
that the original are ones typified as "Bosch, W 75 TL or Bosch W75
T1" (the last letter could be an L or a 1). I called the Bosch company
in Argentina but they didn´t know this code.
¿Someone could tell me which are the right one´s or which other modern
spark plug could work properly on it?
Thanks for all,
Santiago
Oct 31, 2019
562
Hi Santiago
I have the complete specifications for the Albin Gasoline 0-21 engine in English. I don't know if this will help you- maybe someone from our group (like Steve) knows.
If you can use it- I can make a copy and send it to you.
Wilhelm, V-257
Feb 5, 2002
37
I'm currently using either Bosch: on the steel body the numbers M42B and
M43.T1, or Champion D21. The Champion was represented to me as a slightly
"hotter" plug; useful if the Bosch tends to foul easily.
Ric
On Tue, 16 Dec 2008 19:12:08 -0000, ssolda wrote
ssolda
Dec 16, 2008
5
Hi Wilhelm. Thanks for answer my e-mail
Someone write me, with the information about the right O-22 spark plugs.
I have a digital instruction hand book, about the O-21 manual. I will wait a bit, trying to find an English version of a 0-22. Thanks anyway four your offer.
I don´t have Steve e-mail address. If you have it, please, try to send it to me.
Thank you very much,
Santiago
De: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] En nombre de WL
Enviado el: Martes, 16 de Diciembre de 2008 07:35 p.m.
Para: AlbinVega@yahoogroups.com
Asunto: Re: [AlbinVega] Albin motor in Argentina
Hi Santiago
I have the complete specifications for the Albin Gasoline 0-21 engine in English. I don\'t know if this will help you- maybe someone from our group (like Steve) knows.
Wilhelm, V-257
ssolda
Dec 16, 2008
5
Hi Peter. Thanks for the link, I looked it. The o-21 is not the same than the o-22, but some things could be similar. I will write to some people who answer my mail as well.
Saludos,
Santiago
De: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] En nombre de pjacobs55
Enviado el: Miércoles, 17 de Diciembre de 2008 12:46 a.m.
Asunto: [AlbinVega] Re: Albin motor in Argentina
Santiago,
Here is a link to a manual for several Albin motors, including the
021.
¿Is this similar to the 022?
Anyway, it\'s in English.
Hope this helps,
Saludos,
Peter
#1331 \'Sin Tacha\'
Mar 26, 2008
39
Plugs Wide Socket (1") , NGK A6 Gap .7mm
Original Bosch M12B
The original plugs have the 1" socket base. It's difficult to work
with a large socket in that tiny space. If you have a good
automotive supplier in your area, they can find a substitute for the
NGK A6, with a more common socket size, and one that is just the same
plug length and heat as the original. Even the Bosch people seem to
have lost their records of the M12B here in Canada.
I read throught that handbook from the weblink provided by Peter, and
while it is not specific to the 0-22, it is a valuable resource for
maintenance.
I too am looking for an equivalent book for the 0-22, but have not
found one yet.
There is an Albin Engine group through Yahoo too. Some of the
members are not Vega owners, so they would have other helpful hints
about how the engine works on other boats.
I have a PDF of an 0-22 parts manual in English / Swedish. It has
been helpful in showing how the engine is assembled. Let me know if
you need it.
