I've got some of the standard alarms, oil pressure, coolant temperature and exhaust temperature and high level bilge alarm but I guess some are a little different and or, my use of them is different.
I have an electric bilge pump and float switch located at about the 5 gallon mark in a deep bilge. I use the manual bilge pump to clear the bilge keeping that always working. Wired into that float switch is a red light mounted in the companionway.
No horn as the float switch can close under boisterous conditions and hosing out the bilge.
I like it especially sailing or powering at night. 5 gallons will alert us to a broken hose on the water tanks before you lose too much; raw water coolant leak, hot water heater letting go, and of course a hull leak.
It's nice to know the light will be unmistakable above or below decks.
The oil pressure and coolant alarms give peace of mind at night, especially if I'm not at the helm(gauges).
The exhaust alarm I especially added for eel grass or debris clogging the raw water strainer. I suppose it might come in handy for not turning on the raw water as well.
With CNG I skip the gas alarm (but have a solenoid switch we use always).
I don't have a CO alarm but never burn anything overnight.
I've been told by my family we have a low voltage alarm on one of our gizmo's,...but I've never heard it.
