Matt Nelson
I recently purchased a 1993 H23.5. I has an ST50 tridata and I believe Airmar transducers, but I am not sure. I think that they were factory installed, but am not sure because I am the 3rd owner, and the 2nd owner didn't know. Were the Airmar transducers packaged with the ST50 by Autohelm/Raytheon? What model transducers might I have? I know that the speed transducer is mounted aft of the ballast tank slightly off center. Can I remove the transducer while the boat is in the water? Is the depth transducer and the speed transducer the same unit? There is a wire running from the st50 forward into a sealed compartment in the bow, however there is no transducer visible outside the boat on the underside of the hull? What might this wire be for? I haven't opened up the sealed compartment and hesitate to do so. (If any other h23.5 owners read this and know what is in this front compartment, please let me know.)Are there any special calibration procedures that need to be followed for these transducers or the ST50?Thanks for you help!Matt
