Air Intake Redesign
Sep 24, 2018
4,099
Catalina 30 MKIII Chicago
I'm redoing the air intake on my M25XP. The primary reasons for doing this includes proper routing of PCV and replacing the steel wool air filter that's disintegrating. This is a 23hp/57ci engine with a max operating speed of 3100RPM. I found a calculator online to find the liters per minute of airflow coming in to the engine at max speed. Would a 4x2" filter be enough?
Seat of the pants calculation:
There's one reviewer that stated that they saw a drop in RPMs when they installed one filter on their 53' Chevy 235ci gas engine. They discovered that they needed four of them stacked one on top of another to get enough airflow. The same calculator states that this engine requires 18cfm. Since I plan on using a single filter, I divided this number by four to get 4.5CFM per filter. Since my little diesel only needs 3CFM, it should work but I'd love to hear a confirmation from someone with a bit more knowledge on this subject
Ward H
Nov 7, 2011
3,814
Switching to a K&N Filter is pretty common on the M25XP as the can filters with the metal mesh that disintegrates has it gets older.
Here's a link to a C34 forum page where it is discussed and the part number is listed.
K&N RU-2450 filter assembly.
I installed one in 2018 and it appears to work well. It's still clean so I don't anticipate needing to replace it.
Edit: I just checked on line. The price has more than doubled since I purchased mine. Maybe the CFM listed for the K&N can help you decide on a much cheaper option?
1,869
Oday 31 Redondo Beach
... This is a 23hp/57ci engine with a max operating speed of 3100RPM. I found a calculator online to find the liters per minute of airflow coming in to the engine at max speed. Would a 4x2" filter be enough?
I don't know what the spec on your posted filter is but doesn't your calculator show 46 CFM (1,303 LPM) demand for your engine? Not 3CFM?
Maybe I'm reading it wrong.
Likes: Timm R Oday25
Sep 24, 2018
4,099
Something is up with the calc I used. It was giving me different results when I reloaded the page. Another calc estimated somewhere in the range of 52-53CFM which sounds a lot more accurate than 3CFM
Sep 24, 2018
4,099
$60 is a bit steep for a tiny air filter. BTW, you can clean yours when it gets dirty. A dirty gauze based filter will have less flow than a dirty paper air filter according to K&N. I'm leaning more towards replacing a paper filter every couple of years as it takes less time. There's never a shortage of boat projects
Sep 24, 2018
4,099
I couldn't find exactly what I wanted so I designed a filter assembly for the Spectre SPE-4809 that I will 3D print. The outlet is on the inside of the assembly due to height restrictions. There's a hole for a grommet and barb elbow for the PCV hose. I plan on using a catch can on this hose to collect the hose.
I plan on taking the screen out of my original filter to reinstall on the intake, within the filter assembly. I will not be re-using the steel wool from the original filter. This should guard against accidentally dropping parts in the intake manifold during filter changes. I decided against printing this as plastic may become brittle over the years when subject to heat. I don't think engines like to eat plastic.
These filters are often used on vintage VW bugs with a single carburetor. I think this will provide sufficient flow but I won't truly know until spring.
For those that are looking for something pre-made, the EMPI 17-2978-0 filter with cleanable gauze filter and barb is a strong contender. It's a little tall but I think it'll work well for the C30. Price is also less than half of the K&N filter. Note that it is wider and I have not verified width clearance in the engine bay.
Does anyone happen to know the size of the breather hose?
john2
Nov 26, 2022
91
Catalina 310 58 Leimuiden
anything bigger is better than the old piece of s... now we get a K&N also used on HD bikes. this will probably reduces the smoke from the engine to. and the vent hose in the filter instead of somewhere over the filter.
Sep 24, 2018
4,099
The dimensions are roughly the same but instead of tiny holes, the entire filter surface can breath. I'm also installing a purpose designed catch can for the oil to help keep things clean and reduce potential smells
Jan 7, 2011
5,880
Oday 322 East Chicago, IN
Will the filter still act as a silencer? I ran my Yanmar without the metal air filter housing to test something last year, and that was really loud!
Just wondering if there is a trade-off between “entire surface can breathe” and a really loud engine.
Greg
Sep 24, 2018
4,099
Greg
We shall see. It's a tight fit. If there's room, I may make a cover to help reduce noise.
Once upon a time, when I had my first computer that could actually play full length movies, I went to great lengths to get it as quiet as possible. I sprayed a heavy layer of automotive sound deadening all over the inside along with some cushion batting. For the external fans I created a shroud lined with the same materials with the opening pointed towards the carpet. It worked pretty well. I could do something similar if I route the intake to a different location with more space. The longer intake tube alone would help reduce noise. I'd probably take a look at radiator hoses for that application
4,099
The air intake redesign with an oil catch can is complete. If there's enough interest I may consider selling this as a kit. PM me if interested. This shouldn't violate any forum rules as nothing is for sale at this time.
3D Printed bracket for catch can
Camera screws have a narrow section without threads below the head. I took advantage of this so it doesn't become separated from the top of the air filter assembly
Clearance
