T Dugas
I changed the filters on my yanmar 27hp diesel, once changed with new gaskets installed I refilled the filter cups with fuel and tightened them. I bled out all air and everything appeared fine. After running the engine for approx. 30 minutes I had power loss and the engine quit. Bled off air that I thougt was the cause and it was and it happened a couple more times on the trip.I removed the filters again in port, installed new gaskets once again bled the system off. Again appeared alright thou tough to tell except by engine smoothness and RPM's since it has no fuel pressure guage. But low and behold it still has a small amount of air intrusion which causes a slight loss of power and it stalled last trip. Always corrects with air bleed off. Before I remove some hosing and perform a pressure check on the lines was wondering if this has happened to you and how you corrected it.
