Air Filter
CYQK
Sep 11, 2009
610
beneteau first 42 kenora
Time for a new airfilter engine is a 4108 Perkins. Should I purchase one from perkins,it is the mushroom type,or perhaps one of the newer style KLN filters
Anyone with experience on this?
Thanks
Gary
Dec 10, 2010
24
Starwind 19 Lake Perry
I think you're talking about a K&N filter. I do recommend them for any motor vehicle, you'll never have to buy another air filter. You do have to clean them, according to instructions, and have the patience to let that happen. You also have to re-oil them at the same time.
Considering that most boat engines don't rack up a lot of hours, I'd just go with the manufacture's recommendation and just replace at the start of each season.
Thanks
Gary
RichH
Feb 14, 2005
4,773
Suggest you retrofit with a 'dry' type of pleated paper filter; the larger the surface area you can apply the better for 'pressure drop' considerations.
The 'oil-bath' types are only efficient in particle removal at a very narrow 'design point' of specific air flow, and rapidly lose efficiency on 'either side' of air flow that is optimal for the design. These oil-bath types also do not have good efficiency of particulate removal in the 'smaller' µM range .... the smaller the airborne particle, the exponentially more particles will be in 'nature'. Oil bath type 'filters' depend on 'centrifugal force' of particles with significant mass to exit the airstream .. to come in contact with the oil; the smaller the particle (mass and size) the less the centrifugal force generated to 'exit' the airflow to 'impact' into the oil.
Typically in one cubic foot of 'clean' atmospheric air there will be ~10,000 particles at 0,003-0,1 µM; particles at greater than 10µM are 'few' in normal atmospheric conditions.
Small particles will have an additional 'brownian motion' (vibrations) in air/gas and the amplitude of this 'vibration' within a filter media allows the particles to be captured (the amplitude of vibration is larger than the 'pore' of the filter); in liquid (such as in an oil bath-type of filter) there is essentially NO brownian motion involved in particle capture. A 'dry' filter is able to capture ~10-15X smaller particles than when 'wet', even when using the same filter material.
The 'oil bath' types of filters stay 'cleaner' because simply they arent very efficient in capturing 'small' particles and only reach their maximum efficiency at only one distinct amount of air/gas flow.
Use a 'dry' and 'large surface area' filter for *best* particle retention.
Gunni
Mar 16, 2010
5,937
K&N is not an oil bath type air filter. It is simply a cleanable fabric filter with wire mesh reinforcement. They do work exceptionally well and allow improved airflow over the paper filters. You will see better fuel efficiency.
That said, my Yanmar has no air filter, only an air baffle.
zeehag
Mar 26, 2009
3,198
i just use my mushroom...... so far, so good.
Doug L
Sep 9, 2006
80
South Coast 22 MI
An air filter is barely needed on a boat, you do not have the dust and particulates that plague earth bound engines. I would buy a new, stock replacement filter, only if your old one looks dirty. And I would replace it again, only if it looked dirty. Which probably would be never. Certainly not yearly. Note, most outboards do not have any air filter.
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
As with GUNNI, my Yanmar (on my 1998 Hiunter H376) has no actual filter in the filter housing. I just assumed that was the way it came from Yanmar.
