Air conditioning
Bruce
I want to install a 16,000 BTU air conditioner and would appreciate information reagrding the location of the vents and duct work specific to this boat.
Jun 4, 2004
255
Hunter 376 Annapolis MD
a/c
Hunter installed the a/c on my 376. The unit is under the U seat, aft side (adjacent to sink). Vent 1 is just above the backrest of the U on the starboard side close to the freezer. Vent 2 is in the V, forward side of the closet that is above the sink. Vent 3 is in the bedroom, aft side of the starboard closet, facing aft. Vent 1 needs to be at least half closed to get enough heat to the bedroom. Allan
G
Gabor Meszaros
Allen, What is the highest temperature can you get out of your heating/ air conditioning? My unit is a Marine Air (1997 model). Gabor
Bruce
a/c
Thank you very much, good information. Can you advise the size of the out vents and the location and size of the intake vent? Thanks again. Bruce
Jun 4, 2004
255
a/c info
Gabor: I have the same unit.I've found that the max heating or cooling is a function of the ambient air temperature, wind speed, cloud cover and water temperature. Usually I can get the temperature I want, but not always. Bruce: The intake is cut in the seat support about where the calves of the legs are located when sitting on top of the a/c unit. When I go to the boat this weekend I'll measure the size of the intake and outlets. As I recall, the duct diameter is 5 inches. Allan
Oct 3, 2005
159
Catalina 387 Hampton, VA
Hunter 27 with mermaid
The other weekend, I came back from fishing very late and did not want to wake SWMBO by getting in after 3, so I slept on the boat. There was frost on the dock and water temp was 48. Mermaid took the heat up to 72 in about 1 hr. It is on the starboard side under the seat. I plan to winterize the unit in the next couple of weeks.
Bruce
Thanks Allan
Hi Allen, That is exactly the information I needed to get started. Very much appreciated. Thanks again. :) Bruce
