Hello all
I have two units that are fed sea water from a single March Centrifugal pump. Last weekend I had an issue with clogged strainers; the inside as well as the outside thru-hull. Once I cleared the grass system worked fine with good water flow out of both exit thru-hull fittings. However during the clearing process when I was cleaning out the eel grass I fit my hand pump on the intake to the system March Centrifugal pump making sure the system was not blocked from that point. I went to pump and it felt completely blocked and could not get air or fresh water through.... It actually built up pressure and sprayed the boat when I removed my hand pump. Subsequent to that I had cleaned out the grass, reattached the hoses and all worked great with perfect water flow. At first based on my limited knowledge I though there must be some kind of internal valve that opens and closes based on whatever..... again my basic ignorance of the systems. So now I am reading about winterizing and it say that you can easily pump antifreeze through the system. I am new to a/c winterizing...... Am I missing something?
Thanks
Greg
Thanks
Greg
