Tom S
Merrythought. Catalina really isn't prepared
to know your exact needs or installation. If you feel uncomfortable with Boat Wiring and electricity then you should hire a marine electrician or have a trusted knowledgable friend do it, its as simple as that.I can almost gaurantee that a marine electrician will strongly recommend a 2nd 120 VAC inlet correctly installed And I can bet dollars to donuts that if Catalina was installing the AirConditioner they'd do the same and recommend such.Its your decision, knowledge is everything. But for the novice, erring on the side of caution is wise.
