Have the marina add another 30 amp connection
When 30 amps of power from the dock is all that's being supplied, 30 amps is all you're getting on the boat, no matter how you try to split it up. Wiring can overheat, appliances don't get full power, which can damage them...you can even create a power drop to other boats on the dock, causing "brownouts" that trip their breakers. In short, you're creating a fire hazard. It shouldn't cost you more than about $50 to have the marina run a second 30 amp circuit to your boat, on the same meter. Please do it!
