air conditioner
Feb 22, 2016
8
Hunter 28 austin tx
I'm looking for recommendations on a portable air conditioner. i have a hunter 28 in texas, looking to stay cool.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Window units work in the companionway. You can get what I call a "lugable" which sits in a hatch. The best answer is a central A/C unit.
Nov 6, 2006
10,081
a little central unit would be best, but a 6000 BTU or so window unit in the companionway does a pretty good job. The downside is that the hot air (and noise) blows in the cockpit, making sitting there for a sundowner a struggle.. The hatch mounted ones are pretty good but they are expensive for what they are. They do get the noise and hot air out of the cockpit. A central unit would look something like this and if you are good at imagining and installing, it can be installed inside of a coupla 3 days. http://www.marinaire.com/Marine-air-conditioner-9000-btu-110V-p/msba9k2.htm
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
AC in hatch can been seen for sale used in Craigslist and do not where but have seen
them for sale many different places.
A window unit in the compainway is the cheapest way but have heard many complaints
from friends who use them.
Nick
May 24, 2004
7,164
CC 30 South Florida
Have used all of them including a water cooled unit in a Samsonite suitcase and a portable with a 4" hot air exhaust hose. For a boat your size I would recommend the hatch mounted unit (I forget the brand name). It is pricier than a window unit but the convenience of having it away from the companionway is priceless. The built in units are expensive and the portable units too inefficient.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
a used Cruse-Air for the hatch is a good choice ...i say used because they are no longer made ...west marine has one brand but they cost as much as built in ones...craigs list or you may even find one in gear for sale on this site
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I would look into a 10k btu 2 duct portable unit. They have been bashed on here for years but the 2 ducts are the way to go on a boat. I have the single duct unit that is semi- permanently installed in my locker. It's a single duct but I have it installed like a 2 duct. I have an air suction hose from a port feeding air to my enclosed locker. I also have an exhaust hose blowing out the same port. This way it's not using condition air and sucking in hot air throughout the boat. It works pretty darn good and can run off my portable generator.
