The a/c was the orginal equipment. No the warranty ran out some years ago.
In my case....Just a little venting here so be patient.
When my cruise air died, what I was told was an early death on my new hunter. It started developing leaks and then the reverse cycle valve went bad. Plus the drip pan was a rusted mess. We pulled the unit to rebuild it to find out that the compressor
was not the original compressor for the unit. Pretty sure some
sneaky slacker at the factory had swaped out the new unit that was meant for my new straight from the factory boat with an older repaired unit.:naughty:
Okay moving forward .....
I had, had good luck in the past on a previous boat with mermaid marine air-conditioning. So I did a search and found that mermaid from time to time will have new or slightly used rebuilt back to new factory specs with warranty listed on eBay or on their web page . Or you can just call and ask. I struck a deal on a two year old 16,500 btu refurished back to new unit from them and a 5200 btu brand new returned unit that they fully checked out and backed it with a warranty also. Kept my eye out and later another 5200 btu showed up too. Grabbed it also. So I have a main 16500 unit and two 5200 units. One in forward cabin that also ducts to main saloon. And the third 5200 unit ducts to aft cabin and head. No problem holding exactly a steady 74 or optional 64 degrees
in the middle of a Texas summer. What is realy cool is that most times of the year the forward unit will cool the hole boat and if I need a little extra just kick on the aft cabin unit. And when its really hot the main unit can be brought on line.
I hope this help you in making the right decision for what will serve you best.
P.S.....BTW Sorry forgot to mention do not buy their little red raw water pump .....I can safely say been their done that .....Get yourself a little giant!
