Ah, the joys of boat ownership...
1,140
Knutson K-35 Yawl Bellingham
Nothing like the contemplation of where 10 gallons of what looked like crude oil came from in my bilge when the engine only holds five quarts.
Rick D
Jun 14, 2008
7,204
Had That Happen
...when a hose clamp that was put back on 180 degrees from where it had been chafed a small hole into the oil filter. Fortunately, there was still (barely) enough oil to maintain oil pressure. RD
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
Diesel Fuel?
It is pretty oily stuff and mixed with bit of water might seem pretty oil like. Let us know when you track it down.
Steve
Well I Can't Answer That, But...
...I can tell you where four gallons of diesel came from AFTER my survey was completed and I signed the papers... ...pin hole in tank at forward welded edge.
May 5, 2006
1,140
It's not fuel. There are two bilge compartments
forward and downhill of the tank and aft of the bilges with the oil. On inspection and clean out yesterday, these contained only seawater. it looks like the PO was just dumping the oil in the bilges under the engine when changing it. It's impossible to see into these bilges from the aft access or the cabin so who knows how long it's been sitting there. The recent leaking may have cause those to overflow to the bilge pump well. I think my only course is to fill the engine with oil, start it and shine my spotlight under there to see where it's coming from.
Ross
Jun 15, 2004
14,693
The other problem you have is disposing of all that
stuff. Don't let your bilge pump dump it overboard for you.
May 5, 2006
1,140
Already handled. It went into the used oil tank.
The bilges are empty so the pumps won't run, courtesy of Mr. Wet Vac. I just need to clean the oil film off the insides of the bilges now. I'll use that purple stuff and vac it out too.
May 5, 2006
1,140
1961 Knutson Yawl with a Perkins 50 HP 4-108M.
She's a woodie with a fiberglass hull over the wood one.
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Yardarm adjustment
Sounds like the previous owner needs a yardarm adjustment! Put line around his neck and haul him up to the yardarm for a long drop on a short line! But from the outside she looks beautiful.
May 5, 2006
1,140
Thanks, she looks as good inside with all the white,
mahogany and teak. She really sails sweet too. I found the leak. It looks like the filter boss is cracked. The saltwater lift pump is weeping a bit too. I reckon I'm ordering parts today.
