AGM Batteries
P
Pete Burger
A few weeks ago, there were a series of articles, one by Jim, regarding the quality of AGM batteries. On my 430, one of the 8D's has gone bad and I've decided to go to the AGM's for both of them. Questions: When I change both 8D's to AGM's, do I also have to change the 12V starter battery to the same type? Do I have to make some sort of change to the Heart inverter/charger to adapt to the use of gel cells instead of the wet type? Pete Burger "KAILANI"
Rick D
Jun 14, 2008
7,199
For What Little It's Worth..
..Pete, my installer said that the starting battery need not be changed from a wet cell if I go to AGM. The literature I have from Lifeline indicates no changes to charging is necessary. Of course, for that kind of investment, you will want to check with the mfg. RD
P
Paul Bednarzyk
Charger
Pete, While I am no expert on AGM batteries in particular, with gel cell batteries you do have to adjust the output voltage of the Heart inverter/charger. You can do this by adjusting the dip switches on the back of the control panel. There is a fairly good explanation in the owners manual for the inverter. I hope this helps. Paul Bednarzyk
Jim Bohart
AGM's Behave like wet cells
which essentially they are except that the electrolyte is held in the glass mat. JB
Jim Ewing
NOT wet cells
They have different voltage requirements. If you charge them like wet cells you will kill them. Jim "Prospect"
Jim Bohart
My understanding is
That the charging requirements are the same for wet cells that charging systems for AGM batteries need no mods and it's been working in my car for 6 months no change to charging sys there. Same old 18year old alterantor. we also use a bank of 8 of these on the 50 and the Inv/Charger is set for the same as wet cell 4 D's. These are sealed batts it's true but they have the same characteristics as wet cells. The heart invertor should treat them same also. If you do not have a three phase charger I still see no difference. JB
P
Paul Bednarzyk
AGM
Jim, thank you, I didn't realize that that AGM's can be handled like wet cells. I enjoyed meeting you at the St Pete show. Paul Bednarzyk S/V Knot Again
