so i've had this leak in the aft cabin on my 40.5 that ended up rotting the bulkheads. Today was the first day in removing them and testing the water tank. it was a bit of work - first removing the bulkhead, then the batteries and floor from the lazarette to access and remove the tank. All in all a few hours of work
This is a very frustrating leak that is suppressed if I isolate the tank. I am very sure of that, it's been dry for over 6 months since i did that. And the boat has heeled over a lot since then, so i know this is water coming in the aft. To be double, i tasted the water from the leak and it's fresh water. Now, i am testing the tank but so far can't see a link. This would lead me to believe that the issue then would be a connection. I know it's not the one at the bottom - i've tested that one previously. So my guess is that it could come from either the vent or the water intake at the top when the tank is full and the boat heeled over - it is elusive tho
Anyone had the same of similar issue?
see photos of today's job attached
