Aft Traveler Location on a Spirit 23
7
North American Spirit 23 Surrey BC
Hi Don;
I'm fairly new to sailing but I'm anxious to learn! I want to build a boom traveler on the AFT pulpit. I figure I can make it about 5 Ft long (across the transom). The boom is currently attached by 2 cables mounted on the transom on either side of the tiller. I have not seen a setup like this (but I'm sure I haven't seen them all!) Would the angle of the attach points from the car on the traveler to the boom be too excessive to work?
OldCat
Jul 26, 2005
728
Catalina , Nacra 5.8, Laser, Hobie Hawk Wonmop, CO
The Catalina 22 has a short aft traveller - the key to keeping friction low is to align the traveller car to the load - by rotating it forward - thus avoiding side loads on the traveller car perpendicular to the travel direction.
Hope that helps some, if the words don't make sense, I'll post a cartoon of the C22 setup.
OC
Jun 2, 2004
5,802
OC has a good idea, copy one from a C-22. There has to be one near you. As I remember mine the traveler is a stainless rod. The "car" is a stainless bracket that is kind of like a wide(4"?) hose clamp. I kept mine centered since I had no controls for it. But maybe OC has a real traveler bar and car. They are available from lots of sources: http://www.mauriprosailing.com/Merc...Y&Store_Code=MPS&Category_Code=CATALINA22TRAV .
OldCat
Jul 26, 2005
728
I think that you are right about the older boats - they have just that funky bar setup. Newer C22s like mine have a real traveller bar and car on rollers with control lines and 2:1 purchase. The traveller bar is mounted to the round stainless bar above the tiller, but tilted forward to avoid loading across the bar.
It would be easier to use with 4:1 control lines - another project for another day. It would be nicer if it were a Harken ball bearing car as well...
OC
Dec 26, 2008
7
OC
Tilted seems like it might work...good idea!
Dec 26, 2008
7
OC
A cartoon...is it a funny setup??
