aft cabin leak
Paul Bonnes
Have aft cabin leak Rain water collects on floor port side in front of seat Traced leak from under berth than along frame up the inside of hull and can't follow it any more.
May 5, 2004
181
Hunter 386 Little River, SC
Look here, Paul...
Check in the aft cockpit locker on the Port side. There is a "shelf" for storing stuff, then in back of that the diesel and holding tank. I have seen water collect on that shelp, then find it's way into the cabin. Mine does not do this, but I recently saw a 386 that installed a little drain from the shelf so water would not collect. Good luck..... Jeff
