I was doing some work on my boat today and had intended using a 240V jigsaw to cut some fibreglass - fitting some gussets with inspection ports in the top sides of my lazarette bulkhead in order to seal it off. As I progressed I realised there was not going to be enough room to manouvre the jigsaw on the engine bay side and decided it was time to look at buying a Dremel.
The choice seems to involve trade offs between power and manouverability, as well as price.
The machine that is the most manouverable appears to be the "Dremel Stylus" at $100. It is rechargeable on the 240V base, does 7,000 - 25,000 RPM, is 7.2V and comes with about 25 accessories. I am not too sure if those accessories would give me enough range for the type of jobs on the boat. It is not possible to use larger attachements on this model, such as small circular saws.
The other re-chargeable model available is the Dremel L-ion 10.8V model at $170. It is possible to buy an additional flexible drive shaft for this model but that adds another $100 or so. This machine does not look as manourveable as the Dremel Stylus.
The other option is the 240V Dremel 400 Series at about $170 including the flexible drive.
I would be very appreciative on any comments anyone has on their prefered machine and attachments. Would the flexible drive be able to get into as tight a situation as the Dremel Stylus?
By the way these are Australian prices I am quoting - I suspect they are much cheaper in the US.
