Bob Peterson
While preparing my 1990 35.5 Legend for the water, I discovered a 6 inch long crack approximately 5 inches below the joint between the hull and the steel portion of the keel. It is on the aft edge and extends forward. It goes through from side to side.Has this happened to anyone else? Advice before I call a welder??Thank you.
