I have an '86 Ericson 30+ that is in need of some interior work.
Both inside wood walls for the cabin dome have severe water damage and delamination - from an undetermined leak. On the starboard side, thing we bad enough that the headliner is falling down. The wood can't easily be repaired. Also have some damage from water intrusion around the forward end of the V-berth with similar problems including a rotted bulkhead just behind the anchor chain locker.
I've started what is becoming a bigger project than I anticipated - working to replace the cabin walls, the headliner, and the V-berth bulkhead. The plan is to cut out the wood wall panes from the mid-ships bulkhead back to where the chart table and galley is. I've bought 1/4" marine ply and am working on the scarf joints to have the 10ft pieces necessary. I'll butt joint them to the pieces that are in front along the V-berth. Plan is to replace the headliner with a FRP or plastic panel held up with velcro or screws in furring strips that I'll put into place with adhesive. While the headliner is down, I'll rebed all of the deck hardware with butyl tape to try and prevent the water intrusion.
Now the question/problem: The ply side walls seem to be attached to the inside fiberglass with some sort of adhesive. Where things are delaminated, all just flakes away except the outer-most ply which is staying adherent. Where the wood is in better shape, I can't get it off at all without damaging things. I'm looking for advice about the best way to deal with this now that I am a bit over my head. Have thought about a head gun? some sort of solvent? sanding/grinding it out? Looking for advice. Also looking for thoughts about how to deal with the frame for the windows which seem to have their fastening from the inside. The outside is just bare aluminum - no screws. The screws are all on the inside and the frame doesn't seem to want to come off easily.
Last, any advice about what material to use for the headliner?
Hoping that someone has done this kind of re-fit before and might be able to provide some advice.
Thanks,
Mike
Thanks,
Mike
