Hi Guys
I'm fairly new to big boats and just about the break open the piggy bank and make a purchase. I'm thinking seriously about a Hunter 40.5 and one in particular, so I'd like to see if I can pick the brains of all you wise-ones here to make sure I make the right decision.
I want a boat for semi-permanent liveaboard, starting off cruising the Med, maybe going down to the Canaries (especially for winter!) and who knows? Maybe I'll make it across the Atlantic one day. Normally there will only be one or two people on board, four max.
The boat I have seen this weekend is a 1995 40.5, two cabin layout, with a Yanmar diesel. The mast is a Z-Spars, non-standard apparently. The owner described it as a race mast, but the sails are ordinary dacron. The keel has a bulb and winglets and draws only 1.5m, which doesn't seem much.
What should I be looking out for on a boat like this? Is this a sensible choice for the sort of use I am planning? What alternatives should I be considering?
Thanks, in advance.
Thanks, in advance.
