Advice for a newbie on sailboat type
776
Catalina 22 Central Penna.
19 to 20 feet.
I’ve been sailing a Catalina 22 for 20 years on a small lake and during these 20 years have sailed all of the mentioned boats and many others as well as larger boats on the Chesapeake Bay.
The difference between many of the boats mentioned will be what's underwater, that's going to come into play in your situation as far as launch, sailing area, and the other things you have stated over the course of this blog.
The Cat 22 swing keel is a great boat but, with a 5.5 foot draft you may be limited in sailing area in your described waters.
The new water ballast boats would fit your mentioned criteria, but they are newer models and may be out of your price range.
Something you must consider on the price between a powerboat and a sailboat is that the powerboat like a car depreciates real fast over the years because of the major mechanical systems and the operating cost to a point where they are worth junk price. A 15 to 20 year old sailboat will hold its value if it is kept in nice shape. So, after your initial investment, a little maintenance and operating cost you’ll recover most of your cost on resale if the original cost wasn’t that high on an older sailboat.
A fixer upper may cost more in the end if it needs lots of stuff as compared with a boat in good shape and has everything as someone has told you. As you add stuff to your boat it doesn’t increase the market value that much so, buy the boat with the most stuff.
A friend, married with a baby started out with a 19.5 foot for the first year then went to a 23.5 for a couple years, a 25 for 2 years and then a 27 foot trailerable on our lake and then moved it to the Chesapeake. When the child turned 14 he upgraded to a 34. The 27 sold quick because of the trailer but he lost a couple thousand because of the initial cost of a new trailer, all of the other boats he broke even.
If you learn to sail a sloop rigged keel boat any size, you’ll be able to sail any larger boat.
Now, what I’ve witnessed and experienced over the years is if your wife and children would enjoy sailing on a 19 foot, spend a couple nights in it on the water and be willing to do it again next year, you’re ready to move up.
A 19 foot sailboat, with your experience you can launch, recover and rig all by yourself, anything larger you’ll need help.
My oldest sailing friend with the most sailing experience has worked his way up from a sunfish to a 27 footer and is now working his way back down, at 70 he now has a 21.5 and is looking for a sunfish.
Good Luck
Sumner
Jan 31, 2009
5,254
I'll put in a plug for a Mac 26 S with the swing centerboard vs. the 26 D that has a dagger board. If you get into shallow water the centerboard and/or rudder will just swing up.
Very roomy inside for a 26 footer and lots of options for making it into your boat. Huge rear berth.
It is water ballast so has less than 18 inches of draft with the board up and with it up you still have the ballast. Very easy to launch....
.... like above without even a ramp. And setup can be less than 45 minutes. The mast goes up easily with one person and all the rigging stays attached except for the forestay.
We love ours and have towed it all across the country since it is light. I know that might not be important now, but maybe you want to tow down to the Keys or some place else in the future.
You can also ....
...easily beach her like above. Take a look at the old factory video....
http://video.google.com/videoplay?docid=7076785769434785211
It will work in your shallow waters and sails well even with the CB part way down since it has the water ballast and is faster than most of the other boats mentioned,
Sum
[FONT=Arial, sans-serif]Our Endeavour 37
[/FONT] [FONT=Arial, sans-serif]Our Trips to Utah, Idaho, Canada, Florida[/FONT] [FONT=Arial, sans-serif]
Our MacGregor S Pages
[/FONT]
[FONT=Arial, sans-serif]Mac-Venture Links[/FONT]
Ross S
Oct 20, 2011
120
Precision 21 Great Sacandaga Lake
I like the Precision line of boats. The 18, 21 and 23 are similar in design and all are trailerable. I have a 21 and love it. We use it for weekend sailing and find the performance to be fun, yet still forgiving. The cabin is comfortable for the wife and I to spend the weekend on. For anything longer than a weekend I would want something with a larger cabin.
These boats have a shoal keel/centerboard design. They sail well with the board up or down and would do well in the shallow water that you describe.
I find that the build quality is pretty high. The 23 comes with a mast raising system. The 18 and 21 do not, but their masts are lighter. However, on the 21 with a roller furling genoa I find that I need 2 people to raise the mast.
I think that the Precisions would fit your needs and would be worth considering. Hope this helps!
