Adler Barbour thermostat
92
Hunter 37.5 Plattsburgh, NY
Our 1995 Adler Barbour cold machine acts like the thermostat has failed. It makes wild temperature swings and runs way too long before cycling. We had it set on 5 and it went all the way down to 1 degree before cycling, then it went up to 32 and started defrosting itself before turning on again. The unit has worked perfectly for years, running less than half the time. It also seems to be running at fewer amps- now 4.3 when it used to take between 5 and 6. Does anyone have any ideas and where can we get a new thermostat if that's the part we need? Thanks in advance for any help.
New thermostats from WAECO, who bought Adler Barbour. Look in a West Marine catalog or online.
Feb 13, 2004
92
These things are incredibly hard to find. West Marine does not have them and I've been looking for hours online. Help!
May 16, 2007
52
- - C350, Ontario, Canada
Contact Beardmarine They have them in stock (T'stat only = E1391 - $30.00)
Feb 10, 2004
4,235
Hunter 40.5 Warwick, RI
Low current draw on an A-B often means low refrigerant charge. An excellent source of information is Kollmann Marine. Do a Google search- he is a retired marine refrigeration expert who shares info and gives personal guidance.
You may be able to get a new thermostat (if that is your problem) at a local HVAC parts dealer. I think these are very common and available for a fraction of the price that Dometic (alias WAECO) gets. MY experience with them is that the thermostat is high and then they charge big shipping money. They would be my last resort. Your mileage may vary.....
MitchM
Jan 20, 2005
1,031
here is the adler barbour troubleshooting guide excerpt available on the A-B website: i'd call the # and talk to an AB expert (free) before spending $$$ on a thermostat or refrigerant recharge. if it's a compressor problem the cost skyrockets... (almost better and more cost efficient to put in a new AB than repair an old compressor...)
Intermittent compressor/ Poor electrical supply, chronic Review manual, correct wiring
fan operation voltage fluctuations faults, recharge or replace battery
Faulty control module Replace control module
Faulty compressor Call WAECOUSA (860.664-4911)
STUFF TO TRY YOURSELF BEFORE SPENDING $$$:
1) on my old AB coldmachine installed 1980 i found that after 20 years i had to recharge the refrigerant every two years to keep the machine running well.(not a problem when you could still use the old freon, a much more expensive process now since they changed to refrigerants you cant buy and that 'only the licensed AC tech ' can install.. )
1) T Stat issues: AB went to digital t-stats in 97 so i assume yours is the manual knob stle not the newfangled LED panel: so check your manual t stat knob: after 20 years (1980-2000) suddenly our ABColdmachine wasnty controlling temp too well. i found that the inside plastic hub of the manual T stat knob had fractured so the thermostat knob movement was not accurately controlling temp. pull the plastic knob off the t stat control, at look at the underside. "if it's broke, fix it. " i repaired my knob with an electric tie and some superglue... that repair lasted until we sold the boat in 2007.
2) Compressor issues: but we also found that after 27 years the copper lines into the compressor had developed pin hole leaks so it was not holding a refrigerant charge...cooling gradually declined so i had to keep it on coldest to get any cooling at all. and recharge every year 9fortunately a buddy and i swap services -i do his boat electric repairs and he did my AC charge for cost of the r efrigerant... ) as to the voltage into the compressor, you could also try cleaning and dielectricing the hot terminals into the rear of the compressor unit and into the cooling fan to make sure you have the best connections for your battery to suppply power to the compressor...clean the dust off the fan unit and any part of the compressor you can easily reach .
if noen of these selfhelps fix your problem...
hmmm your unit is 17 years old now ??
Kirie-Elite Elite 37 Niceville, FL
Try going to rparts.com. You will find most components, as well as installation and troubleshooting information.
