Adler-Barbour Refrig
22
Catalina 38 Wilmington
I've just gotten around to addressing the freezer/refrig. Made sure all the wires were connected, turned on the circuit breaker, adjusted the thermostat control and nothing. Not exactly nothing. I heard a whirring sound that gave me hope, but it turned out to be only the fan, mounted behind the compressor. Don't know where to go from here, but I'm eager to learn.
Jul 14, 2013
22
The boat is an 81 and the unit came with. Model number, papers, etc are on the boat and I'm in my office. It's called a "Cold something or other", pretty sure.
Apr 22, 2011
934
Hunter 27 Pecan Grove, Oriental, NC
If you have the time for a DIY project, I recommend Kollmann-marine:
http://www.kollmann-marine.com/default.aspx
I emailed him with my model # and the problems I was having. He sent me a trouble shooting document that showed that the circuit board was probably bad. Sent him the board and he bench tested on his equipment and it did not check out. He sent me his recommended replacement at a very reasonable price and it has worked fine for three years.
Jul 14, 2013
22
As it happens I am in the mood for a DIY project. I've run across the Kollman Co in my investigations and will take your advice. Thanks very much.
