I recently successfully converted my elderly Cold Machine refrigeration system from R-12 to R-134a and it was a lot easier and way more successful than some "experts" that I consulted said it would be. My old compressor had died, I wanted to learn somethig about refrigeration, so I figured I had nothing to lose so set out on this project. On Craigslist I found someone selling a nearly new Danfoss BD-50 compressor along with a controller very reasonably. This compressor is a direct replacement for the original R-12 one so mechanically it was very simple. I used a propane torch and copper tubing cutter along with typical plumbing procedures to accomplish the removal and re-installation of the copper lines. Make sure you clean up the copper fittings well with steel wool and use flux on the solder joints. After installing Schrader valves on both the low-pressure and high-pressure lines, and replacing the dryer, it was a simple matter of going to Wal-Mart and buying an automotive can of R-134a with a fill valve and pressure gauge attached. Once fully assembled, I attached the refrigerant can to the low-pressure side, powered on the Cold Machine and added refrigerant a little at a time. Keep an eye on the pressure on the fill gauge and keep adding refrigerant until the pressure is in the green (normal) band on the gauge. Pretty quickly the evaporator inside the cooler began to frost over and things were looking good. I can report that even here in SW Floriida at the peak of summer I am getting a 61 degree F. differential from the cabin temp. to inside the icebox (100 degrees in the cabin and 39 in the box). My 1985 Hunter 31 has about 5 cubic foot inside the box and the evaporator is freezing ice cubes very well. The retrofittted system draws 5 amps peak from my batteries...I expect this to go down as the ambient temps go down in a few months and the compressor's duty cycle drops. All in all this was a pretty easy project and was a lot less expensive than a total replacement, and I got to learn something about refrigeration in the process. Contact me if you need any more info at k7mx@comcast.net. Good luck!!
