Adler Barbour ColdMachine Compressor
287
Beneteau Oceanis 352 NYC
After blowing a few fuses, I've figured out that the compressor is bad by plugging and unplugging wires and the fuse only pops when the compressor is plugged in...Tried the old hit it with a hammer suggestions to free a stuck solenoid inside the compressor but it didn't work.
Question: can I replace just the compressor or get into buy and fitting a new machine?
Jun 11, 2004
73
- - Ft. Lauderdale FL.
If this is a older 4 pin connecter at compressor module and fuse that blows is plugged into module I have replacements. If $150 replacement does not solve problem you get the $150 back. This is how sure I am that module is bad and no need for new compressor.
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
uh...not good.. where did you get that idea? it doesn't work.. never worked on hermetic compressors.. It used to work on really large old semi hermetic compressors
Richard is your best source really.
Jun 11, 2004
73
You can not get return mail so if interested email me at richard@kollmann-marine.com
If module fuse blows, Module is bad 999 times and compressor is good. Try my module for 30 days and money back if it does not solve your problem. Your cost is only shipping.
Jun 4, 2004
287
Richard,
just got a chance to install the module I purchase from you and it worked great. I do have to change the mounting plate as the footprint isn't the same as the old one but my fridge is working again!!!!!
Oct 29, 2005
2,366
I also uses AB coldmachine. Its working fine but I would like to keep contacts/weblink of Richard K for future reference in case I need to repair the coldmachine. Any contact/weblink info? Thanks.
Jul 14, 2012
22
ODay 322 7385 San Diego
Hi Richard, Im considering to install refrigeration in my ODay 322, now it has the regular ice box which came in the boat from the factory,
can you advice me or recommend me the right equipment to install with as low consumption as possible?
Thanks in advance for your help.
Rick D
Jun 14, 2008
7,206
Refrigeration Issues
Richard was a guest expert once on this site and is kind enough to drop by once in a while. However, for a question, best to go directly to his site as marked in another post. FYI, he has saved me many hundreds of dollars working through refrig issues. He also has/had a book available on his site that is terrific!
