adjusting transmission linkage...3GM30F
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
It doesn't engage in forward until the shifter is all the way forward against the stops.
How do I adjust the linkage?
Rich
Nov 6, 2006
10,206
Try these from this site:
http://forums.hunter.sailboatowners.com/showthread.php?p=720295&highlight=transmission linkage
Could be the linkage or the transmission itself.. If you search on “adjust linkage” too, ya may find some good stuff.. Someone had posted the procedure to adjust the internal transmission linkage.. but don’t try that until ya loosen the remote linkage and see if the tranny shifts fine when done manually.. Be sure to keep human parts out of the rotating things .. beware of shirtsleeves and the like when checking this.. good luck, Rich
Dec 2, 1999
15,184
Rich:
You may want to check your cable too. I would suggest that you remove the cable from the tranny and see how it shifts by hand. You cable housing may have come loose from it's mount on one end or the other.
Be sure to check out the cable housing too.
