Jay
Have a 5hp Honda 4-stroke. Thinking about the Garlick Non-offshore model that can be adjusted to the angle of the transom. When the motor mount is attached to the transom, does there need to be something between the gelcoat and the motor mount (other than 4200 adhesive)? Do the mounts come with a gasket or something?I am planning on purchasing a mount soon. Already have a backing block (marine plywood) and will fill in any uneeded holes with epoxy, as per suggestion by Peter S (I think). Hopefully there is no water in the transom wood as the seal around the old mount appears to be in good shape.Checking on the boat this weekend. Anything else I should look for?sv Winter Solace
