The previous owner installed an adjustable genoa car system on our 1991 Legend 37.5. The system uses a 5-1 block advantage, approx 3/8" line, to pull the cars forward. This works if the cars are not too highly loaded. Under heavy loads I cannot budge the cars. With a system like this, should we be able to pull the cars forward under heavy loads? To pull the cars aft, the PO used bungee cord line to connect the aft end of the sliding car to some point at the stern of the boat. We have replaced those lines with newer and heavier bunge cord line. With any load on the cars, we cannot pull the cars aft. Is the intent with adjustable genoa cars to only pull them back when the load is taken off the cars? What other ways (i.e arrangments of lines) can be used to pull the cars aft?
