It's a sailboat
Our 1983 Catalina 30 has been in the water for the past 15 years. Removed for bottom painting three times and once for hurricane repair (did bottom paint # 3 then). Boat has been all over the channel islands off CA and down to Baja (where it lives now) and up and down the Sea of Cortez. The 5411 engine has been a workhorse with no problems. It is flushed with fresh water after use (sink plumbed to sea water intake) and stored for six months with fresh water and radiator anticorrosive while we return to the US. Other than an impeller now and then, one raw water pump replacement, it has been flawless. Oh, after 14 years did redo exhaust riser (total cost: $10). This year I pumped 15 gallons of diesel out of the tank and disposed of it as it was over 7 years old. Gave it new diesel. Underpowered? That is relative. We sail, use the motor on windless days and getting in or out of the slip. On a "bad" day, if there ever are any when sailing, motoring with full sails gets her up pretty well. And, of course, sails up dampens swell action. Down here, if the motor needs to come back to the US, two guys can lift it out, carry it, bring it back to the US for ?. Met a guy this year with 8700 hours on his motor! I have 1600 hours. Reliable, inexpensive, a Kubota tractor engine with part availability, sips fuel, and actually, an auxillary. Sure wouldn't throw out a great boat for having this engine. Would I replace it (if we have total failure) with more hp? Sure, but certainly based upon the past 15 years the little beast will keep purring along for many more hours.
