Tom S.
Yikes...I have to install an inspection port
in the holding tank? Won't that introduce another potential source of holding tank leaks? Have you done this and found the ports not to leak (even when under pressure) Which one is better the WM inspection ports or the Ronco.The reason I am *Very* concerned is because I have inspection ports on my Ronco water tanks and they leak all the time I overfill the water tanks. The leak occur where the threads to the port screw in. I (and others) have tried to do numerous things to prevent the ports from leaking but nothing seems to help.If I have to put an inspection port in the holding tank I think I will skip trying to do this.
