Adding transmission oil
Tim Pinkham
Hello, I drained the transmission oil last fall but had trouble adding the new oil back in. It goes in REALLY slowly. I took off the black cap and added oil but gave up as it was taking so long. Now I have to finish the job. Any idea what I am doing wrong? Thanks for your help, Tim La Juin
Pat McCartin
A few questions...
Tim, Which engine do you have? What oil are you using? Pat
Tim Pinkham
green
18hp Volvo Oil is same as engine oil which I don't recall. Nothing very unique though. The opening for adding the oil just seems so small. But, I'm pretty green.......
Pat McCartin
Oil
I don't have alot of experience with Volvo but, the trans hole should be about 1/2 to 3/4" in dia. When you pull the cap there should be a dipstick, and marking on the outside identifying the trans oil. If this is the place you are trying to fill, try warming the qt of oil. Warm oil flow's better.
Tim Pinkham
Thanks!
Thanks Pat and Tom! The cap was so big I thought the oil would go in faster. Heating it makes sense. I'll try again. Thanks!!!
