How about for a 2nd reef point?
I am also considering putting in a 2nd reef point (a #3, higher than the OEM) for when winds are above 18-20. My current experience is that the boat sails fine until the 1st reef goes in at about 12-15. Once around 18 I really need a higher reef.So, I was thinking of using the same reef line with a cheek block and a cam cleat. Run the line out of the boom end, through the 1st reef point, down to the cheek block/cleat, then up to the 2nd reef point, back down to the boom and tied off at the bail. To put in the 2nd reef I would uncleat the line at the boom end and pull the reef line in tighter. Would still have to go forward to put the forward reef point on the hook at the mast.Does this make sense? Is there something I'm missing in this idea?ThanksJim Covey
