Hi Brian, I added midship cleats to our...
boat two years ago, and they have become invaluable. Now when I kiss the dock, it is the first line I secure until the boat settles down, then I secure the other lines. Before it was a circus even with a crew. It helps make solo docking a breezeWe mounted the cleats onto the toe rail of our 1991 P42. I ordered the cleats from Hunter Marine to match the originals. First, I cut a slot out of the aluminum rail (just the vertical part of the rail) to match the bow and stern cleat cutouts. The rail bolt holes matched the cleat holes and Hunter included bolts and nuts long enough to mount the cleat.The finished job looks original. Hunter Marine told me that the rail joint was strong enough to handle the cleat, just the same as the bow and stern cleats. No deck holes need to be drilled, or backing plates, chocks, or shims and spacers to raise the cleat above the rail.Hope this helps.Terry
