adding halyards
Jul 5, 2017
66
Hunter 25.5 Arizona
I have two extra sheeves in my mast for halyards but no line to use as a messenger to run new line through. What's the best way to do this? I was thinking of just buying 30' or so of household electrical wire and using the ground wire.
-na -NA Anywhere USA
If the mast is down, hold it up at an angle and shake it with a weight or snake in it with a messenger line added to the weight. the higher the angle is better but be safe doing that.
Likes: Submarine
