Hi there
I have a 1995 Hunter 26. Presently it has a deck organizer and rope double clutch on the starboard side.
I want to add the same to the port side so I can bring the toping lift and reefing lines to the cockpit.
Hunter has moulded places on the deck to mount the hardware,but I have no access inside the cabin to fasten nuts on. It seems Hunter installs the deck hardware with bolts and nuts then installs a finished ceiling leaving an inch or so between the two to run wires etc.
My question is can I use stainless steel wood screws to secure the hardware to the deck, there seems to be about 1 1/2 inches of solid fibgerglass to screw to, as I don't really want to cut holes in the finished ceiling.
Thanks Ken
Thanks Ken
