Adding deck hardware to '94 H30
Dale
I'm about to add a second rope clutch and deck organizer to port of companionway. Has anyone done this on a Hunter 30? Since there is no access to the underside of the deck, I'm not sure of the best way to secure the hardware.
Mike Jaeger
It is very easy if you have the time.
Dale, You have to take the deck orginizer off. Be sure to have some silicone silant on hand to reinstal it. We installed a spinnaker halyard, and two turning blocks at the mast base. Then a three pulley deck orginizer and a SpinLock two line clutch on the deck. Just like the starbord side. You need a drill and taps to do the install. Be carefull when you drill only through the top deck.Use lots of sealant. We ran the outhall to the main through the second block. You can get the turning blocks for the mast base at Rig-Rite. See the link below. I don't have any close up pic's, but I can take some for you if needed. Good Luck.
