Bruce
I have an '88 Mark II, and would like to add 3-4 blocks at the base of the mast to bring some lines aft to the cockpit. (Except for a single bail facing aft attached to the bottom of the mast, there's no place to fix any hardware).What is under the deck at this point? It looks like the mast is stepped on a very solid "arch" from beam to beam, supported in part by the wooden compression post. Can I drill through it? Or is it metal, which means I would have to drill and tap at the deck? Any other solutions?Thanks in advance!Bruce
